2007 Toyota Rav4 cranks too much before starting
2007 TOYOTA RAV4
62,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVETOMAN
Hello:
My 2007 Toyota RAV4 cranks for a long time before it starts on the initial start then seems to start easier after that.
I was scheduling the 60K maintenance and didn't see a tune up in the maint manual at 60K. Is there one at 60K?
The dealer wants $189 for oil etc and $120 form the tune up. Are these fair prices?
Thank you,
Dave
Would you recommend just changing the spark plugs or ?
Thank you,
Dave
Oct 12, 2009 at 11:16 AM
Check and test the coolant temperature sensor its job is to enrich the fuel during cold starts if okay do an oil/filter change and replace the plugs yourself-Prices varies with locations-
Oct 12, 2009 at 12:00 PM
