1993 Toyota Previa No Start
THURDDEN
I was driving my van around last week and it started to sputter and stall when I press the accelerator to fast. When I was on the interstate it ran fine, this only happened from a stop. The next day when I went to start it, it would not start. I was getting good crank. Ive checked the fuel, fuel pump, injectors, fuses, spark plugs and wires. Everthing seems to be there for it to start and the computer is not giving a code. I'm lost. Does anyone have any suggestions? :?:
Nov 19, 2006 at 8:09 AM
  • 75,988 POSTS
Go underneath and pull the coil wire and ground it check for a blue spark while cranking. inspect the EFI and Ignition fuse to include the EFI and COR relay
Before we go to the airflow meter
Nov 20, 2006 at 7:26 PM
Suggested Repair
Ground the coil wire and check for a blue spark while cranking. Inspect the EFI and ignition fuses and the EFI and COR relays before testing the airflow meter.
Conversation Summary
A 1993 Toyota Previa sputtered and stalled when accelerated quickly from a stop, then would not start the next day despite a good crank. The owner checked fuel, the fuel pump, injectors, fuses, spark plugs, and wires and found no computer code. The expert advised checking for spark at the coil wire and inspecting the EFI and ignition fuses plus the EFI and COR relays before moving on to the airflow meter.
