1993 Toyota Previa
have a Toyota Privia that the battery was disconnected for awhile (weeks) when the battery was reconnected it will turn over but won't start. The book mentions a theft deterent system however nothing on how to reset it. I have tried to close all doors and use the key to in each lock locking and unlocking to try to reset but no change. Tested the electrical componets (distributor, coil, ect.). My problem is the ECM when I tested pins 4, 5, 17, and 18 of plug (D) which sends voltage to distributor and get 12volts, but when I reconnect plug (D) the voltage out of those pins is zero which leads me to believe that an input on plug (D) is causing this change. My question is there a theft deterent system that cuts this power and how do I reset it if there is? Any other thoughts on what it might be?
SPONSORED LINKS
Wednesday, May 26th, 2010 AT 3:00 PM
