Where is the Thermostat?
MATTHUB80112
1994 Toyota Truck, 3.5 l 5spd manual 4wd
Trying to replace the thermostat, can't find it.
i assumed it was in the top hose connection to the engine, nothing there
Feb 10, 2007 at 3:47 AM
  • 75,988 POSTS
Its adjacent to the water pump-its probably been removed
Feb 10, 2007 at 9:06 AM
LOSTINMARS
  • 222 POSTS
okay lets start with the right engine. unless this is some model only released outside of the states toyota didn't use a 3.5 engine. in 1994 they had a 3.0 and 1995 they went to a 3.4.
Feb 10, 2007 at 2:09 PM
  • 75,988 POSTS
[quote:85b579bfd8="lostinmars"]okay lets start with the right engine. unless this is some model only released outside of the states toyota didn't use a 3.5 engine. in 1994 they had a 3.0 and 1995 they went to a 3.4.[/quote:85b579bfd8]c
It has to be 3000cc engine unless it came from Bolivia
Feb 10, 2007 at 2:59 PM
  • 75,988 POSTS
Follow the upper hose till its dead end, do not remove the clamp-remove the 2 bolts-reverse the process for reinstallation.
Feb 10, 2007 at 3:41 PM
