1995 Toyota Pickup heater doesn't heat
1995 TOYOTA PICKUP
85,000 MILES • 4 CYL • 2WD • MANUAL
HUMES
The heater fan operates and blows air but it is not heated at all.
What is the most likely cause and part replacement needed?
Dec 6, 2007 at 5:00 AM
For a start-check the coolant level, inspect the thermostat. Start the truck get it up to operating temperature-feel both heater hoses should be the same temperature if not check for clogged hose and heater core. Also inspect the heater control valve.
Dec 6, 2007 at 7:19 AM
