2004 Toyota Tundra Power Steering Whine
ODIE28
I own a 2004 Toyota Tundra, 41000 k 4.7l V-8. The power steering "wines" and is hard to turn after the vehicle warms up. When cold there are no problems, it acts like there is air in the system the lines have been bled and fluid levels remain normal. Any help is appreciated....
Mar 3, 2007 at 2:43 AM
LOSONE
  • 1,616 POSTS
It is a common problem when a rack and pinion goes bad especially in col;dweather. Smell the power steering fluid and look for a change in color. Check for metal in the fluid. 75% it is the rack and 25% it is the pump.
Good luck losone
Mar 3, 2007 at 3:22 AM
Suggested Repair
Inspect the power steering fluid for odor, color change, and metal particles. A failing rack and pinion is the more likely cause (about 75%), with the pump less likely (about 25%).
Conversation Summary
The owner of a 2004 Toyota Tundra reports power steering whine and hard steering after the vehicle warms up, with no symptoms when cold. Fluid level is normal and the system has been bled. The expert says a failing rack and pinion is common, advises checking fluid smell, color, and metal, and estimates the rack is more likely than the pump.
