2001 Toyota Tundra Headlight Problem
RANCH HAND
2001 Toyota Tundra
270,000 miles, V6
I changed the battery yesterday and noticed that my headlights are not working properly. Could I have blown the fuse when reconnecting the battery, or could I have blown the headlights (dim does not work - lights come on when switched to brights...but the brights indicator light on dash does not light up)? I do not see the fuse for the headlights...is there a special place for that fuse? AND the battery indicator light is still on on my dash...is not not properly gounded?
Thanks for your help.
May 14, 2007 at 9:34 AM
  • 75,988 POSTS
[quote:13443c23a3="Ranch Hand"]2001 Toyota Tundra
270,000 miles, V6
Thanks for your help.[/quote:13443c23a3]
If the headlite fuses are blown,you won't see the bright lites.The problem here could be your combo switch or ground.
As for the alty-you need to find out why that idiot lite is staying On. Could be a bad connections or the IVR.
Check all the fusible links in the power distribution box.
May 14, 2007 at 10:08 AM
RANCH HAND
Thanks for the info...and I don't mean to sound all blonde on you, but...where will I find the power distribution box....and the combo switch on the headlights...where would that be...
Again, thanks for the quick resposne.
May 14, 2007 at 10:17 AM
  • 75,988 POSTS
[quote:f7dd33038e="Ranch Hand"]Thanks for the info...and I don't mean to sound all blonde on you, but...where will I find the power distribution box....and the combo switch on the headlights...where would that be...
Again, thanks for the quick resposne.[/quote:f7dd33038e]
Its in the engine compartment at the L/Fender driver's side. you'll see the box there. Inspect every fuse there.
The Combination switch is where you activate the lights and trun signals.
May 14, 2007 at 12:07 PM
RANCH HAND
If it is not the fuse...is it possible that the alternator is now bad and that is why the battery light is staying on?
May 15, 2007 at 9:23 AM
  • 75,988 POSTS
[quote:5fe3607335="Ranch Hand"]If it is not the fuse...is it possible that the alternator is now bad and that is why the battery light is staying on?[/quote:5fe3607335]
Lets do this get a voltmeter read the battery no load voltage-record it. Start the engine read he battery again, it should increase atleast 2volts over the battery no load, if not its not reconditioning the battery.
Recheck the connections on back of the alty, also look for power from the ignition switch at the connector this is the one that initiates the field excitation before the alty be on its own.
May 15, 2007 at 9:32 AM
Suggested Repair
Inspect every fuse and fusible link in the underhood power distribution box on the driver's-side left fender. Check headlight grounds and the combination switch (the stalk that controls lights and turn signals). For the battery light, measure battery voltage with the engine off, then running; voltage should rise at least 2 volts. Recheck alternator connections and ignition-switch power that excites the alternator field.
Conversation Summary
After a battery replacement on a 2001 Toyota Tundra, the low beams do not work, high beams come on without the dash indicator, and the battery warning light stays on. The expert said blown headlight fuses would kill the high beams too, so the cause may be the combination switch or a ground, and advised checking all fuses and fusible links in the engine-compartment power box. If the battery light remains on, test charging voltage and recheck alternator connections and field-excitation power.
