2001 Toyota Tundra O2 Sensor Connector Fix
JOEYBOY_60
  • 5 POSTS
I own a 2001 Toyota Tundra, V6, 24 valve, 2 wheel
drive automatic with 73K miles. The dealer told me the O2 sensor that is located before the catalytic converter is bad and needs to be replaced. I took it out but the sensor doesn't seem to disconnect from the small gray plastic connector the wires are attached to. The wiring from the sensor seems to join another set of wires that form a sort of "V" and then continue on up the engine compartment. I didn't want to force the wiring from the plastic connector, but I don't see any way I can disconnect the wiring so I can repalce the sensor. Where does the wiring disconnect from the sensor so the sensor can be connected. I haven't purchased the new sensor because I am not certain if I can do this or not. Please tell me what you can about this problem.
Apr 14, 2006 at 11:47 AM
LOSONE
  • 1,616 POSTS
Take a small screw driver and place it is the small loop of the connector. Press down gentle while pulling on the connector. It will seperate cleanly with no damage. It takes a bit getting used to Yoda connectors. Good luck
Apr 18, 2006 at 10:46 AM
Suggested Repair
To release the upstream O2 sensor connector, insert a small screwdriver into the connector's lock loop and press down gently while pulling the connector apart. It should separate without damage.
Conversation Summary
The owner of a 2001 Toyota Tundra was told the upstream O2 sensor before the catalytic converter is bad. After removing the sensor, they could not see how to separate the gray plastic wiring connector and did not want to force it. The expert explained that a small screwdriver pressed into the connector lock loop, while pulling the connector, releases it cleanly.
