1998 T-100, 71,000 mi, 2WD 6cyl
I had to install a plug to my boat trailer from scratch. The old plug was gone so I had to figure out where the wires went. I must have figured wrong. After plugging in the trailer wiring and starting the truck, the signals will flash 2-3 times and then burn the 10a fuse for signals and the 15a fuse for the stop lights. Replacing fuses does not help, same thing happens?
Where should I start looking for the problem?
Thank you. Great forum!
JDA
JDA
Aug 17, 2007 at 5:19 AM
