1994 Toyota Pickup AS Reed Valve Noise
BLUEJEAN
  • 20 POSTS
I have a 1994 toyota pick up 3.0 (v6) eng. My AS reed valve is making noise. What is a AS reed valve and what dose it do? What should I do about the problem?
Apr 7, 2007 at 3:33 AM
  • 75,988 POSTS
[quote:c16d9005b2="bluejean"]I have a 1994 toyota pick up 3.0 (v6) eng. My AS reed valve is making noise. What is a AS reed valve and what dose it do? What should I do about the problem?[/quote:c16d9005b2]
AS reed-air suction- its purpose is to reduce carbonmonoxide and hydrocarbons emission
What it does-is draws air into the exhaust manifold to accelerate oxidation, using vacuum produced by exhaust pulsatiion in the exhaust manifold.
It is similar to an air injection pump operation-
Apr 7, 2007 at 10:31 AM
BLUEJEAN
  • 20 POSTS
When I give it some gas and release, it makes gurgling noise. Does this suspose to operate this way or is reed valve bad?
Apr 8, 2007 at 7:00 AM
  • 75,988 POSTS
[quote:297dbdf316="bluejean"]When I give it some gas and release, it makes gurgling noise. Does this suspose to operate this way or is reed valve bad?[/quote:297dbdf316]
Its suppose to do that-its different if you don't hear it-
Apr 8, 2007 at 9:41 AM
Suggested Repair
No repair is indicated. The gurgling noise when releasing the throttle is normal AS reed (air suction) valve operation; concern would be if the noise is absent.
Conversation Summary
The owner of a 1994 Toyota Pickup with a 3.0 V6 asked what the AS reed valve does and whether a noise means it is bad. The expert explained that the air-suction reed valve draws air into the exhaust manifold to reduce carbon monoxide and hydrocarbon emissions, similar to an air injection system. The owner then described a gurgling noise when accelerating and releasing the throttle. The expert said that noise is expected and that the concern would be if it were not heard.
