1983 Toyota Pickup Front Axle Binding Noise Fix
JESWADE
i have a 1983 toyota 4x4 about 500,000 mile its a 22r engine.. when i lock my hubs in and shift into 4x4 i have what sounds like a bindeing noise..im sure it comming from front axle just not sure where or what it is... any help would be app..
thanks
jw
Sep 18, 2007 at 8:00 AM
MERLIN2021
  • 17,250 POSTS
Have you checked the axle's lubrication latly? 1/2 a million miles, I think you done got yer money's worth!!! If you want another 1/2 mil...take the hubs aprt and inspect it!
Sep 18, 2007 at 8:06 AM
JESWADE
yes i take them apart yearly to regrease them..it sounds like it more in the shaft area..
Sep 18, 2007 at 8:24 AM
MERLIN2021
  • 17,250 POSTS
Could be...there are 2 different types of joints in front, 1 U-Joint 2 CV-Joint both will make noise when out of grease, both need to be replaced, not greased! You'll need to remove the brakes and the spindle and pull axle thru the front!
Sep 18, 2007 at 11:04 AM
Suggested Repair
Inspect the front axle shaft joints. Noisy U-joints or CV joints that have run dry should be replaced, not just greased. Remove the brakes and spindle, then pull the axle through the front to inspect and replace the worn joint.
Conversation Summary
The owner of a 1983 Toyota 4x4 pickup with a 22R engine and about 500,000 miles hears a binding noise from the front axle when the hubs are locked and 4x4 is engaged. The hubs are regreased yearly and the noise seems to come from the shaft area. The expert says a dry front U-joint or CV joint can cause the noise and should be replaced rather than greased after the brakes and spindle are removed and the axle is pulled out.
