86 Toyota truck starting problem
GYMMY
  • 1986 TOYOTA PICKUP
86 Toyota truck, 120,000 mikes, 22R engine, 4 spd. I've got a good battery, battery and starter connections. When failing, I can step on the clutch to the start position and hear the click of a switch (part of the clutch linkage?). The switch sometimes connects and I can start the engine but now it's unreliable. Is there an external or internal replacable switch on the transmission connecting the voltage to the start solenoid? What's it called or part number so I can do a part search? Thanks for your help. G 10/20/07
Saturday, October 20th, 2007 AT 3:15 PM
BLACKOP555
  • 10,371 POSTS
Thers the ignition switch and the starter relay.
Saturday, October 20th, 2007 AT 9:06 PM
DEARHUNT05
Its sounds like it may be you nuetral saftey switch but it may also be a problem with your main relay located on right side of passenger compartment under kick panel may need to test that
Saturday, March 15th, 2008 AT 10:34 AM
