2002 Ford Pickup Blown fuse, door ajar light, and interio
2002 TOYOTA PICKUP
KYLEMACE3
Electrical problem
2002 Ford Ranger Pickup 4 cyl 55000 miles
The #2 fuse (10A) keeps blowing out. I tried to replace it with a 15A fuse but it blew through that too. This fuse controls the transmission, pass. air bag deact. switch, back up lamps, and blower motor relay etc.
Also, this may or may not be related. Sometimes the interior light will stay on after starting/killing the ignition. It goes off by itself at seemingly random times. Also, the door ajar light comes on rather frequently too. What the heck is going on here?
Any suggestions as to the cause and/or solution to these?
Thanks a million for your help fellas.
Mar 19, 2008 at 6:16 AM
2CARPRO JACK
  • 11,533 POSTS
Try unplugging the circuits that you know are on the fuse one at a time until it doesnt blow the fuse anymore. I dont condone going up in amps on the fuse at all, the circuit is designed for 10 amps and wont be able to handle much more or wire damage could happen
Mar 19, 2008 at 7:11 AM
