1993 Toyota Pickup Emergency brake warning light
1993 TOYOTA PICKUP
600,000 MILES • 6 CYL • 2WD • MANUAL
The emergency brake dashboard warning light will not go out when the emergency brake is disengaged. I'm not feeling any drag so I'm sure the brake is completely disengaged but the light stays on. Could this be a major problem or something that I, myself, can fix? And if the latter....how?
Jul 18, 2009 at 7:19 PM
  • 31,937 POSTS
HI there,
I think that this may be the low brake fluid warning light as well, check this first.
mark (mhpautos)
Jul 18, 2009 at 7:30 PM
Nope. Brake fluid level is full.
Jul 23, 2009 at 5:03 PM
  • 31,937 POSTS
Hi there, well it may be a faulty switch at the hand brake lever, you will have to test this with a multi meter next.
mark (mhpautos)
Jul 23, 2009 at 5:46 PM
Ok.. Thank you. I'll give that a try.
Jul 23, 2009 at 6:31 PM
