1993 Toyota Pickup toy not fun to run
REHCAET
  • 1993 TOYOTA PICKUP
  • 6 CYL
  • 4WD
  • MANUAL
  • 163,000 MILES
Engine hesitates at 45mph. I changed the plugs, wires, rotor, distributer cap, and fuel filter.
Wednesday, April 21st, 2010 AT 5:37 PM
Inspect and test the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Thursday, April 22nd, 2010 AT 2:33 AM
