1993 Toyota Pickup not starting
LOGGERMAN814
  • 1993 TOYOTA PICKUP
  • 4 CYL
  • 4WD
  • 203,456 MILES
I have a 1993 toyota pickup with 22RE MOTOR AUTO TRANS and it wount start
Friday, October 17th, 2008 AT 6:09 PM
Do below
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Friday, October 17th, 2008 AT 7:04 PM
LOGGERMAN814
I have tested the spark and its a redish blue how do I go about testing fuel psi
Friday, October 17th, 2008 AT 7:19 PM
Check the fuel pressure-hook up at the fuel filter
Friday, October 17th, 2008 AT 7:26 PM
LOGGERMAN814
If I got good psi there replace the fillter? And I thank you so much for the this is the first toyota I have had and once again thanks
Friday, October 17th, 2008 AT 7:42 PM
Comeback with the fuel pressure readings that way I know what direction to take to help you out-
BTW do you hear the fuel pump come On when key at run position?
Friday, October 17th, 2008 AT 7:46 PM
LOGGERMAN814
Thanck guys for all the help I looked over everything that you told me to do than my wife cam out to my shop to get the dozer and ask if I checked the wiers to the pump and there it was a broke wire thanks again
Saturday, October 18th, 2008 AT 6:24 PM
