1993 Toyota Pickup pedal slowly sinking to floor.
GIGGY
Brakes problem
1993 Toyota Pickup 4 cyl Two Wheel Drive Automatic
when at a stop sign or red light the pedal is high and solid but will slowly sink to the floor, almost like there is a leak in a line but i am not losing any fluid.
Feb 4, 2009 at 6:50 AM
  • 75,988 POSTS
Without a leak and slowly going in while appled points to an internal leak in the brake master cylinder
Feb 4, 2009 at 6:53 AM
GIGGY
can this be repaired or should i look for a replacement master cylinder?
Feb 5, 2009 at 5:31 AM
  • 75,988 POSTS
Replace it-don't go the rebuild kit way unless you can do it
Feb 5, 2009 at 5:50 AM
GIGGY
ok, i think i can do that. another issue i have is an oil leak. after i bought the truck, i was checking it out under the hood and found what turned out to be the crank pulley bolt laying on the frame, the big one in the center. the truck just had a head job done and i assume they forgot to put it in. dont know how it didnt fly apart. anyway could this be the root problem of my oil leak?
Feb 21, 2009 at 3:55 AM
  • 75,988 POSTS
The crankshaft pulley bolt will no cause it to leak
Feb 21, 2009 at 7:29 AM
