the truck set up for about a year. When i tried to start it would not start. The fuel pump is not getting any fire to it. I can run a hot wire to it and it will start. the only fuses i can find are marked EFI one is a relay the other a 15 amp fuse the both are ok. Is there something else i can check? I cannot find a break in the wire i have traced into to the firewall from the pump forward I lose it after that. please help!
Feb 11, 2007 at 8:12 PM
