1981 Toyota Pickup Old Fuel Tank
DDHJR13
This truck was my bother-n-laws it has been sitting for about 10 yrs, He was a fireman and died in a very unfortunant accident while building a new home. he loved this truck and i want to fix it but theres alot i don't know about autos.
Anyway i am puting it back on the road and need to purge the fuel from the tank. Q- How do i do that without removing the tank?
Jan 21, 2007 at 9:40 AM
  • 75,988 POSTS
Best method is to remove the tank-the john wayne type siphon it out then again them debris is stiill in there. Pick your choice
Running it till its out of gas is a bad idea.
Jan 21, 2007 at 1:04 PM
  • 75,988 POSTS
I gave you my best idea how to remove that fuel from the tank.However you choose to degrade me by a bad point. You should have did your research before coming on board with your problem-Don't expect a perfect answer from us in one shot Remember we're not there. AS for your drain plug you still need to get to the pick-up screen to clean it up real good-unless you got one of them electric eyeball you can sent in there to do the inspection and clean up.
BTW its okay to demand for answers if you have donated,in your case you didn't do that. It takes money to run this site. Like the old saying goes-money talks...............
Jan 23, 2007 at 3:43 PM
Suggested Repair
Remove the fuel tank to drain the old fuel and debris, then clean the pickup screen thoroughly. Siphoning leaves debris behind, and running the engine until the tank is empty is not recommended.
Conversation Summary
The owner of a 1981 Toyota Pickup 4x4 with a 22R engine wants to purge old fuel after the truck sat about 10 years, preferably without removing the tank. The expert says removing the tank is best because siphoning leaves debris, running it dry is a bad idea, and the pickup screen still needs cleaning.
