1991 Toyota Pickup Fuel Pump No Power
TJGOZ79
fuel pump isnt receiving power , jumped to battery from fp port in diagnostic connecter, truck started but didnt stay running. Checked Air flow meter for power but none found in center of connecter. Also checked E1 port in diagnostic connecter for power and found none. help
Nov 29, 2006 at 5:18 AM
BACKYARDMECHANIC
  • 337 POSTS
have tried checking the fuel pump fuse to see if its any good. Also check the fuel pump relay and see if it is getting power. Hope this helps. :) Backyard mechanic
Nov 29, 2006 at 7:34 AM
  • 75,988 POSTS
[quote:ba8bb32d02="tjgoz79"]fuel pump isnt receiving power , jumped to battery from fp port in diagnostic connecter, truck started but didnt stay running. Checked Air flow meter for power but none found in center of connecter. Also checked E1 port in diagnostic connecter for power and found none. help[/quote:ba8bb32d02]
Try checking the EFI fuse and Circuit Opening Relay
Nov 29, 2006 at 5:49 PM
Suggested Repair
Check the fuel pump fuse and fuel pump relay for power, then check the EFI fuse and circuit opening relay.
Conversation Summary
The owner of a 1991 Toyota Pickup reports the fuel pump is not receiving power. Jumping the FP port in the diagnostic connector to the battery allowed the truck to start, but it would not stay running. No power was found at the center of the air flow meter connector or at the E1 diagnostic port. Experts recommend checking the fuel pump fuse and relay, the EFI fuse, and the circuit opening relay.
