1991 Toyota Pickup Clutch Problems
230,000 MILES • 6 CYL • 4WD • MANUAL
TOOHT4TWAT360
I have put a new clutch, pilot bearing, throw out bearing, clutch fork, slave cylinder, and clutch master cylinder. I still could not get the trans. to shift. tore the dash apart and found the bracket the brake and clutch pedal are on, was broke. Got it welded and reinstalled. Bleed the system AGAIN!!! Still can not get the clutch to disengage enough to shift. Is there a special way to bleed the clutch system on a Toyota to get all the air out?
HELP!!!!!!!
May 20, 2008 at 11:03 AM
  • 31,937 POSTS
Hi there,
There is no special way to bleed these clutches. you only have to make sure that you don't run low on fluid while bleeding. Just check that there is not excessive free play at the clutch pedal, you only need a bout 2mm free play. Check this first.
Mark (mhpautos)
May 20, 2008 at 12:11 PM
