clutch replacement gone wrong
100,000 MILES • 2.4L • 4 CYL • RWD • MANUAL
MBELDEN67
i replaced the clutch, flywheel, pilot bearing, throw-out bearing. after putting everything back together it drove and shifted smoothly for sixty miles but it was making a loud grinding noise every time i let off the gas pedal. the only time it was silent is when i had the clutch pedal fully depressed. even making the noise in idle on neutral. any advice before i take the whole thing apart again?
May 28, 2017 at 6:09 AM
CARADIODOC
  • 34,413 POSTS
Most vehicles have an inspection cover in the front/bottom of their transmission bell housings. If yours has one, remove it, then see if the noise is gone. They are responsible for a lot of horrendous noises when they get slightly bent of are not seated exactly right.
May 28, 2017 at 1:27 PM
