1990 Toyota Pickup still not work with new ECU
1990 TOYOTA PICKUP
KIRENDA
  • 5 POSTS
Computer problem
1990 Toyota Pickup 6 cyl Four Wheel Drive Manual
So i baught a truck that wasnt running, and there is a 4-runner engine in it and the mechanic got it going but then it quit. so i baught a new ECU computer thinking thats what it was and still nothing. and when i plugged in the ECU i turned the key and the flashers went on at a rapid paced and the headlights turned on. what else could cause the truck not to work if the computer isnt the problem. please just give me idea of what it can be. im thinking maybe a bad connection..
Sep 2, 2010 at 3:05 PM
MADMIKE1735
  • 951 POSTS
new ecu may need to be reflashed, but before you spend money on that, does this thing have an aftermarket security alarm???? for somereason they always haunt vehicles....
Sep 2, 2010 at 3:17 PM
KIRENDA
  • 5 POSTS
will the after market alarm not let the truck start though?
Sep 3, 2010 at 3:13 AM
KIRENDA
  • 5 POSTS
so the alarm system was taken out already. what else could it be then.
Sep 3, 2010 at 6:47 AM
MADMIKE1735
  • 951 POSTS
is this cranking over but not starting, or is it not cranking????
Sep 4, 2010 at 6:29 AM
KIRENDA
  • 5 POSTS
yes it is cranking there is nothing wrong with the starter. and even when the key is not on the headlights turn on and the blinkers.
Sep 5, 2010 at 9:19 AM
KIRENDA
  • 5 POSTS
but there is no spark when i crank it over. so i thougt maybe a ground wire.
Sep 5, 2010 at 9:20 AM
