1990 Toyota Pickup alternator out
ECREEK
  • 1990 TOYOTA PICKUP
  • 6 CYL
  • MANUAL
  • 250,000 MILES
The alt brushes are worn out. While waiting for new alt, drove the p/u for a couple days and used batt charger to recharge batt when at destinations. On 3rd day the p/u started chugging along like it was hitting on 2 or 3 cyl then stopped after about a mile. The batt still had lots of charge, but when restart was attempted, the starter would only click. Turned on lights and tried to stat, the starter clicked and lights dimmed slightly but stayed quite bright.
ecreek
Wednesday, November 19th, 2008 AT 12:56 PM
DOCFIXIT
  • 18,828 POSTS
Have you tried jumping? If batt is full charge 12.6V then solenoid is not engaging starter motor.
Wednesday, November 19th, 2008 AT 1:09 PM
The battery indicator can be green and if its 12.4 and below-she won't crank over
Load test the battery and if doesn't hold up 9.6 volts in 10secs can it.
Wednesday, November 19th, 2008 AT 1:14 PM
