Alternator Bolt specs (both tension and lower mounting bolts)
1995 TOYOTA PICKUP
150,000 MILES • 2.4L • 4 CYL • 4WD • MANUAL
LEVICA
Both mounting and tension bolts are badly worn and have always loosened up.
Because of where I live and my health, I cannot pull the bolts and match them in town. Nor do I trust they are the original bolts and washers to begin with.
It would be great to know the best washers and nuts or fastening system to prevent loosening, the grade and size of each bolt, and any other identifiers. This is so I can either order them or have them picked up without disabling my only transportation.
Any help would be appreciated. Thank you, Kirk Giberson
Jun 24, 2015 at 2:50 AM
RACEFAN966
  • 5,029 POSTS
Ok as for size of the bolts and such is not something most can look up about the only one that might would be the dealer. As for the grade most alternators use standard grade 5 bolts no need for much more, Now for you problem of them loosening up well my thoughts are this if the bolt fits good and everything then I would blue loctite them. Blue Loctite is a anti vibration grade and will fix the problem of the bolts vibrating loose and yet if you ever have a problem with the alternator you will be able to get the bolts back off. I hope this answer helps anything else please just ask.
Jun 25, 2015 at 12:17 AM
LEVICA
That was no answer. But thank you for being nice about it.
Jun 25, 2015 at 1:57 AM
LEVICA
for the sake of my donation....please dont respond unless you have the answer.
Jun 25, 2015 at 2:03 AM
THIS IS MIKE
  • 686 POSTS
We appreciate your donation. After some research I was able to locate the replacement mounting hardware for your alternator.
You can find the alternator hardware here: http://www.toyotapartswebstore.com/
They are special order so you will need to contact them via their phone order desk.
1995 Toyota Pickup 2.4L 4wd manual -
Alternator -
1 - short top bolt - #9011908654
1 - long bottom bolt - #9010110083
2 - regular washers - #9020110005
1 - spring washer - #9451201000
1 - bolt - #9017010015
Jun 25, 2015 at 4:12 AM
LEVICA
Absolutely awesome!
Thank you!
Jun 25, 2015 at 5:10 AM
THIS IS MIKE
  • 686 POSTS
We are glad to help.
Aug 4, 2015 at 3:22 AM
RACEFAN966
  • 5,029 POSTS
Thanks Mike I don't have access to Toyota for part numbers and specs and also my internet has been not working correctly to just recently. Again thanks for the help.
Aug 6, 2015 at 12:00 AM
THIS IS MIKE
  • 686 POSTS
I am glad to lend a hand when I can. :)
Aug 6, 2015 at 2:48 AM
