1987 Toyota Pickup idle
BREW4U
  • 1987 TOYOTA PICKUP
  • 4 CYL
  • 4WD
  • MANUAL
  • 197,000 MILES
I just changed the starter in my truck. Everything went smooth but now it does not idle at all. Will start every time with gas petal assistance and will drive fine, when foot is off the petal it dies. I looked for something I might have disconnected but found nothing
Sunday, August 24th, 2008 AT 4:19 PM
Look for a disconnected vacuum hose, try raising the idle speed by turning the idle screw and recheck the ignition timing.
Sunday, August 24th, 2008 AT 4:40 PM
BREW4U
Idle screw had no effect. Vac hoses check out
Sunday, August 24th, 2008 AT 5:50 PM
What type of fuel system do you have - Carb or EFI?
Sunday, August 24th, 2008 AT 6:11 PM
BREW4U
Carb. I looked again for any loose hoses, but found none. Are there any wires that could effect the idle like that
Sunday, August 24th, 2008 AT 6:15 PM
The choke plate could be sticking not opening also check the PCV and EGR valves
Sunday, August 24th, 2008 AT 6:56 PM
