HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Pickup
Engine
Symptoms
Stall While Driving
1986 Toyota Pickup truck will not stay running
86MUSTANG
MEMBER
1986 TOYOTA PICKUP
4 CYL
2WD
MANUAL
300,000 MILES
Truck would not start. I found a bad ignition control mod. Now truck starts but shuts off immediately.
Sunday, January 6th, 2008 AT 9:24 PM
MECHANIC
Hi there,
Check the coil voltage when you start and it stops, also check the idle solenoid inn the carby. Will it run on fast idle? Check fuel pressure as well.
Mark (mhpautos)
Sunday, January 6th, 2008 AT 9:45 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
1986 Toyota Pickup Truck Runs Then Stalls Out And Won...
Engine Mechanical Problem 1986 Toyota Pickup 4 Cyl Four Wheel Drive Manual 145000+ Miles This Is My Husband's Truck And It Starts And...
Asked by
tyli07
1 IMAGE
1986
TOYOTA PICKUP
VIDEO
Is it Safe to Drive Check Engine Light?
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
1986 Toyota Pickup Engine Stalls
My Engine Idles Rough After It Warms Up Then It Will Stall When I Come To A Stop, Tried Increasing Idle Screw Can Smell It Running Rich At...
Asked by
toy--trouble
1986
TOYOTA PICKUP
Hello, My Truck When Its At An Idle It Starts To Sputter Out The Exhaust Tip And Isn't A Clean Idle. When My Idle Goes Up A Little, When I...
Asked by
troy21
1 ANSWER
1986
TOYOTA PICKUP
Toyota Pickup Starts And Dies
I Have A 1987 Toyota Pickup 2.4 Efi 4x4 With 190,000 Miles On It. It Will Turn Over Start Then It Will Run For Like 2 Or 3 Seconds Then It...
Asked by
blatner
TOYOTA PICKUP
Engine Shuts Off After Releasing Gas Pedal
My Engine Will Start But Will Shut Off After I Release Gas Pedal.
Asked by
Jp Taisacan
1 ANSWER
1991
TOYOTA PICKUP
VIEW MORE
Topdon OBD2 Scanner Review - This thing rocks
Code Read Retrieval/Clear Mercedes-Benz C230
Code Read Retrieval/Clear Mercedes Benz
