Toyota Pickup starts and dies
BLATNER
  • TOYOTA PICKUP
I have a 1987 toyota pickup 2.4 efi 4x4 with 190,000 miles on it. It will turn over start then it will run for like 2 or 3 seconds then it will die. Why is it doing this?
Sunday, November 4th, 2007 AT 8:04 PM
BLACKOP555
  • 10,371 POSTS
What I want you to do is start up the truck and let it die out like ususall after it dies out hook up a fuel pressure tester. If your getting no fuel pressure change pump.
Sunday, November 4th, 2007 AT 8:09 PM
Also check the EGR whether its crack opened by carbon.
If your pressure is up to specs. And it dies out. Try this and observe the engine's behavior. Get a jumper wire hook it up at the coil positive terminal and to the battery positive post start the truck and see what happens. Then report back to us.
Sunday, November 4th, 2007 AT 11:38 PM
BLATNER
Ok I did that ans the truck is still starting and dieing. Also I put a new fuel pump on the truck.
Monday, November 5th, 2007 AT 8:38 PM
BLACKOP555
  • 10,371 POSTS
Beautiful. How much voltage are you getting at the fuel pump connectors, if nothing check for a fuel pump shutoff switch and make sure it is not set off also check the relay and fuse. If those are good there may be a cut or cracked wire shorting out.
Monday, November 5th, 2007 AT 8:47 PM
BLACKOP555
  • 10,371 POSTS
And I still wanna know how much fuel pressure your getting right after truck dies out.
Monday, November 5th, 2007 AT 8:48 PM
BLATNER
I dont have a fuel pressure tester. Also where is the shut off switch? I have replace both the fuse and relay.
Monday, November 5th, 2007 AT 9:08 PM
BLATNER
Monday, November 5th, 2007 AT 9:19 PM
BLACKOP555
  • 10,371 POSTS
Not sure yours has one its usually under the driver side dash up against fire wall.
Tuesday, November 6th, 2007 AT 6:48 PM
