1985 Toyota Pickup
BEAVERDAM
  • 1985 TOYOTA PICKUP
Engine Mechanical problem
1985 Toyota Pickup 4 cyl Four Wheel Drive Manual
cranks but will not start
Saturday, October 9th, 2010 AT 7:35 AM
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, cap and rotor, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it and keep testing
Saturday, October 9th, 2010 AT 3:38 PM
