No spark
ALEMAN33
I have a 1993 Toyota Paseo and I can’t get any spark. I replaced/installed the following: brand new distributor (including cap, rotor, coil), sparks plugs, wires, igniter, EFI relay. I check voltage on coil and it was good. I even cranked the engine while checking coil voltage and it was good. The car was parked for about two years. I try to retrieve computer code, but I didn’t get any. Any advice or ideas will be greatly appreciated.
Mar 17, 2007 at 10:09 AM
  • 75,988 POSTS
[quote:3c61221b41="aleman33"]I have a 1993 Toyota Paseo and I can’t get any spark. I replaced/installed the following: brand new distributor (including cap, rotor, coil), sparks plugs, wires, igniter, EFI relay. I check voltage on coil and it was good. I even cranked the engine while checking coil voltage and it was good. The car was parked for about two years. I try to retrieve computer code, but I didn’t get any. Any advice or ideas will be greatly appreciated.[/quote:3c61221b41]
What voltage? the power input to the coil or the center of the coil.
Check the Ignition and EFI fuse
Mar 18, 2007 at 1:43 AM
ALEMAN33
It's fixed. I replaced the computer and it started like a champ. thank you for your help.
Mar 22, 2007 at 4:48 AM
