1995 Toyota Tacoma Wipers Stay On
TOYOTA
NATEDAWGG1981
I have a 1995 Toyota Tacoma four cyl, and mileage of 140,000. My windshield wipers stay on and will not shut off. Even my intermittant wiper stays on regular wipe and the sprayer does not work now when I push the button. What could be the cause, and how do I fix it?
Feb 3, 2007 at 12:17 AM
LOSONE
  • 1,616 POSTS
Do they cut off when the key is turned off?
The most common problem with wipers in the model year is the wiper switch. You have to repalce the entire assembly on the column.
Good Luck Let me know
losone
Feb 5, 2007 at 3:58 AM
NATEDAWGG1981
When the ignition is cut, they do turn off, and sometimes they turn off when I hit the switch to stop wiping the windshield.
Feb 5, 2007 at 6:58 AM
Suggested Repair
Replace the entire wiper switch assembly on the steering column. That is the most common cause on this model year when the wipers will not shut off normally.
Conversation Summary
The owner of a 1995 Toyota Tacoma reports wipers that stay on, an intermittent setting that wipes continuously, and a washer that does not spray. The expert identifies a failed wiper switch as the most common cause and says the entire column assembly must be replaced. The owner adds that the wipers stop when the ignition is turned off and sometimes stop when the switch is set to off.
