1998 Toyota Altezza Failed Smog
TOYOTA
CORCONIAN
I have a 1998 toyota altezza rs200 (same as lexus is200 but better engine). The car failed the exhaust emissions text as follows:
Low Idle (860rpm): CO = 7.32 vol% (fail), HC = 0 ppm (n/a)
High Idle (2910 rpm): Lambda = 0.853 (fail), CO = 5.29 vol% (fail) and HC = 224 ppm (fail)
From this informaion can you advise me what might be wrong with the engine, I'm thinking the air flow meter might be problematic, what do you think? much appreciated. :?
Apr 12, 2007 at 6:21 AM
  • 75,988 POSTS
[quote:2a851333c0="corconian"]I have a 1998 toyota altezza rs200 (same as lexus is200 but better engine). The car failed the exhaust emissions text as follows:
From this informaion can you advise me what might be wrong with the engine, I'm thinking the air flow meter might be problematic, what do you think? much appreciated. :?[/quote:2a851333c0]
Check the O2 sensors might be the problem, also the Cat and Air Injection system.
Apr 12, 2007 at 10:03 AM
Suggested Repair
Check the oxygen sensors, catalytic converter, and air injection system.
Conversation Summary
A 1998 Toyota Altezza RS200 failed an emissions test with very high CO at low idle and rich lambda, high CO, and elevated HC at high idle. The owner suspected the airflow meter. The expert recommended checking the oxygen sensors, catalytic converter, and air injection system.
