HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Emission
Smog
Fail
SPONSORED LINKS
95 Camry LE 6 cyl. 3.0; 250k, Failed emission test NOx
PKEENAN266
MEMBER
1995 TOYOTA CAMRY
My 95 camry runs great but I just failed an emission test in Ohio for Nitrogen/Oxygen compounds (NOx).
The oxygen sensor has needed replaced for 3 years, but I am too cheap to have it replaced.
Any ideas to reduce the emissions?
SPONSORED LINKS
Wednesday, August 8th, 2007 AT 1:18 PM
MECHANIC
Find the EGR clean it out or replace it. Its job is to lower combustion temperature to prevent formation of nitro oxides
SPONSORED LINKS
Saturday, August 11th, 2007 AT 4:34 PM
Please
login
or
register
to post a reply.
Related Smog Fail Content
1995 Toyota Camry Just Barely Failed Smog On Co%
I Failed The Ca Smog Test With Co Percentages Of.47 (15 Mph) And.46 (25mph) And Then Got It Tuned Up - Timing And Spark Plugs Is All I Know...
Asked by
george.catlin
1 ANSWER
1995
TOYOTA CAMRY
My Car Did Not Pass Smog Due To The Hc Being High
Could It Be Because Or The Catalytic Converter Or Bad Mass Airflow Sensor? Hi Hows It Going I Have A 1992 Toyota Camry Le That Did Not...
Asked by
sergio138
1992
TOYOTA CAMRY
Help With 1997 Camry That Failed Ca Smog Test Twice
Hello, This Is My First Post In The Forum. I Have A 1997 Camry Xle (v6) With 140,000 Miles On It That Failed Its Smog Test Twice. Here...
Asked by
SoCal
1997
TOYOTA CAMRY
Failed Smog Computer Problem?
My Car Did Not Pass Smog So I Took It Into The Shop. My Mechanic Says That The Catalytic Converter Is Working, That The Emissions Are Fine...
Asked by
Gretch1234
1 IMAGE
1999
TOYOTA CAMRY
Quot;92 Camry Emissions Failed
1992 Camry Ct Emission Test Failed Car Failed For High Levels Of Nox… About Twice Allowable I Have 230k Miles On It. It Has Some Issues...
Asked by
BakerDavidW
1992
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
What to Do When a Check Engine Light?
Code Read Retrieval/Clear Mercedes Benz
Check Engine Light Safe to Drive?
Online car repair manuals
