1998 Toyota Tacoma Rough Idle
TOYOTA
BLUEJEAN
  • 20 POSTS
I have a 1998 toyota tacoma 2.4l 2wd. It has poor performance and idles rough. I gave it a full tune up including wires. I also replaced both o2 senors, tps, and egr valve. The oil is clean, and no signs of a head gasket leaks. What can it be? Help!
Apr 2, 2007 at 1:22 PM
  • 75,988 POSTS
Check the fuel pressure and also look for a vacuum leak and check out the EGR system.
Apr 2, 2007 at 11:56 PM
BLUEJEAN
  • 20 POSTS
I took off the plenum and in all cyclinders showed a wet fuel related residue. Is this a fuel pressure trouble or a sensor trouble?
Aug 25, 2007 at 10:20 AM
  • 75,988 POSTS
[quote:a23356bfae="bluejean"]I took off the plenum and in all cyclinders showed a wet fuel related residue. Is this a fuel pressure trouble or a sensor trouble?[/quote:a23356bfae]
Sounds more like leaking injectors or excessive pressure-do a fuel pressure test.
Aug 25, 2007 at 12:10 PM
Suggested Repair
Perform a fuel pressure test to check for excessive pressure or leaking fuel injectors. Also inspect for vacuum leaks and verify the EGR system.
Conversation Summary
A 1998 Toyota Tacoma 2.4L with rough idle and poor performance still ran poorly after a tune-up, new wires, both oxygen sensors, the TPS, and the EGR valve. Oil was clean with no signs of a head gasket leak. The expert advised checking fuel pressure, vacuum leaks, and the EGR system. After the owner found wet fuel residue in all cylinders, the expert said it sounded like leaking injectors or excessive fuel pressure and recommended a fuel pressure test.
