idling
TOYOTA
TOTI ORDONO
hello. i have a toyota tamaraw fx (auv) with a 5K carburator type engine. it has a 200,000km+ mileage, 15000 cc engine. my problem is the idle is not smooth. the rpm would suddenly drop to about 4 - 5,000 but would recover immediately. i tried to raise the idle to 8,000 to 10,000 but it is still there.
Sep 6, 2007 at 1:41 PM
  • 75,988 POSTS
[quote:d558b97778="toti ordono"]hello. i have a toyota tamaraw fx (auv) with a 5K carburator type engine. it has a 200,000km+ mileage, 15000 cc engine. my problem is the idle is not smooth. the rpm would suddenly drop to about 4 - 5,000 but would recover immediately. i tried to raise the idle to 8,000 to 10,000 but it is still there.[/quote:d558b97778]
When was the last major tune-up? You can do this find the fuel mixture screw-close it all the way in and back it out 2 turns-now adjust the idle screw to 9,000,now go back to the mixture screw start closing it-one at a time till you feel the engine idling rough,back out the screw till it starts smoothing out-then do the other one-once you complete adjusting the mix screw raise it to 8000.
Sep 10, 2007 at 8:24 PM
