1991 Toyota Previa Hard Steering When Hot
TOYOTA
DANEFIELD
I OWN A 1991 TAYOTA 4WD PRIVIA VAN WITH 106500 MILES. WHEN THE VAN IS COLD THE STEERING TURNS EASILY. WHEN THE ENGINE BECOME HOT, THE STEERING IS HARD TO TURN WHEN I AM NOT MOVING. WHEN THE VAN IS MOVING IT TURNS OK. IS THE SYSTEM BAD?
May 25, 2007 at 11:47 AM
  • 75,988 POSTS
[quote:7860339469="DANEFIELD"]I OWN A 1991 TAYOTA 4WD PRIVIA VAN WITH 106500 MILES. WHEN THE VAN IS COLD THE STEERING TURNS EASILY. WHEN THE ENGINE BECOME HOT, THE STEERING IS HARD TO TURN WHEN I AM NOT MOVING. WHEN THE VAN IS MOVING IT TURNS OK. IS THE SYSTEM BAD?[/quote:7860339469]
Try checking the PS fluid level, if low fill it-now turn the steering all the way to the left till it stops now look at the level, do the same thing to the right look at the level if it needs filling do it till it hits the full mark. what you are doing is bleeding it.
May 25, 2007 at 4:44 PM
Suggested Repair
Check the power steering fluid level and fill it if low. Bleed the system by turning the steering fully left and fully right, checking the level each time, and topping it off until it stays at the full mark.
Conversation Summary
The owner of a 1991 Toyota Previa 4WD with about 106,500 miles says steering is easy when cold but hard to turn when the engine is hot and the van is stopped; it steers normally while moving. The expert recommends checking and filling the power steering fluid, then bleeding the system by turning the wheel fully left and right while monitoring the level until it reaches the full mark.
