1991 Toyota Camry Charging Lights
TOYOTA
LEOKELLY
i have a 91 camary and the brake,charge,engine light came on then the battery went dead. I had the battery checked and it was bad replaced and the lights came on a little while later is it the alternator
Thanks
Jun 10, 2006 at 3:39 AM
SYNCRAIT
  • 235 POSTS
yes i suggest replacing the alternator and the belt at the same time.... to reassure you, you can always have the old one tested at the store when you bring it in just for peace of mind....good luck :)
Jun 10, 2006 at 11:14 AM
B0B77
The easiest way to know if it's your alternator is start the car and with it running remove the positive battery cable if it dies you need a new alternator! if not than it's fine.
Jun 21, 2006 at 2:19 AM
Suggested Repair
Replace the alternator and drive belt together, and have the old alternator tested at the parts store for confirmation.
Conversation Summary
The owner of a 1991 Toyota Camry reported that the brake, charge, and engine lights came on and the battery went dead. After the battery was replaced, the lights returned. An expert recommended replacing the alternator and belt together and testing the old alternator for confirmation.
