Before you do anything check the battery no load-should read 12.4volts or better is it? Less than that we're right back to battery drain.
When all fuses are remove and light is still there, disconnect the alty-if the lite disappears better check the wiring on the alty to the ignition switch and could be the alty, but its new.
If you're using an ammeter 30ma is excessive parastic draw
Good Luck
Thursday, April 26th, 2007 AT 6:57 PM
