1988 Toyota Corolla Carb Floods When Off
TOYOTA
STU GALVIN
hi....my carburetor continues to have fuel run through it even when its turned off. If i dont pull the fuel line off, it fills the cylinders up. It is running rough as guts and often stalls when slowing down. It will also surge when backing off the accelerator. It has recently started to ping at the rear which i feel is a small backfire but am not sure?
Jun 6, 2007 at 9:34 PM
  • 75,988 POSTS
[quote:e2bbbf9a5d="stu galvin"]hi....my carburetor continues to have fuel run through it even when its turned off. If i dont pull the fuel line off, it fills the cylinders up. It is running rough as guts and often stalls when slowing down. It will also surge when backing off the accelerator. It has recently started to ping at the rear which i feel is a small backfire but am not sure?[/quote:e2bbbf9a5d]
What are we working on here-you need to follow the help guidance to get a quick answer.
Jun 7, 2007 at 11:40 AM
STU GALVIN
sorry!!.....
it is a 1988 toyota corrolla, 1.6, 360,000km's
Jun 7, 2007 at 8:16 PM
  • 75,988 POSTS
[quote:1db64f6002="stu galvin"]sorry!!.....
it is a 1988 toyota corrolla, 1.6, 360,000km's[/quote:1db64f6002]
Get the Carb rebuild and check the fuel pressure.
Jun 7, 2007 at 11:25 PM
Suggested Repair
Rebuild the carburetor and check fuel pressure.
Conversation Summary
The owner of a 1988 Toyota Corolla 1.6 reported fuel continuing to flow through the carburetor with the engine off, filling the cylinders unless the fuel line is disconnected. The car also runs roughly, stalls when slowing, surges when the accelerator is released, and has a rear ping that may be a small backfire. The expert advised rebuilding the carburetor and checking fuel pressure.
