1992 Toyota Corolla Fuel Filter Location
WHEATAMANDA
  • 5 POSTS
where is the fuel filter in a 1992 toyota corolla and how hard is it to change
Feb 26, 2007 at 2:09 PM
KRYPTONITEFUSION
  • 15 POSTS
i can't help u locate ur fuel filter..i alone didn't know where my fuel filter was even though i knew what it looked it...only because theres this other stupid thing that looks like a fuel filter as well was in plain sight.
anyways my guess is that ur fuel filter is locate at the back of ur engine.
as far as changing it...well lets say my first time doing it went smooth. u'll probably need extensions and most likely need to raise the car up.
i was told that before u remove the fuel filter u'll need to release the pressure and such...which is just disconnecting the EFI fuse, and battery...after that its as easy as putting on a shoe
im not sure what answers u really want...im new both to this forum and to automechanics...u might get better answers from someone here
Feb 26, 2007 at 3:56 PM
  • 75,988 POSTS
[quote:f39f879604="wheatamanda"]where is the fuel filter in a 1992 toyota corolla and how hard is it to change[/quote:f39f879604]
Its underneath the intake manifold drivers side to get at it-has to be done under.
To depressurize-start it up then remove the fuel pump fuse or relay wait till stalls then go for it.
BTW is this a 5M-GE or a 7M
Feb 26, 2007 at 4:16 PM
WHEATAMANDA
  • 5 POSTS
[quote:100031cdd8="rasmataz"][quote:100031cdd8="wheatamanda"]where is the fuel filter in a 1992 toyota corolla and how hard is it to change[/quote:100031cdd8]
BTW is this a 5M-GE or a 7M[/quote:100031cdd8]
i dont know what 5m or 7m means all i know is it is a 16 valve 4 cilinder
Feb 27, 2007 at 1:04 AM
MMPRINCE3000
  • 133 POSTS
If it's like a '91 it is on the drivers side directly below the master cylinder. The top is a banjo bolt and the bottom is a double inverted flare connector.
Best access is to remove the air cleaner assy. and hose to TB. Then remove the drivers side splash cover and the left front tire, you can see the bottom of the filter. Use a flare wrench on the bottom fitting and remember on the banjo bolt there are two small copper washers you don't want to lose.
Install the lower fitting first and be cafeful not to crossthread it.
The engine is more than likely a 4A-FE or 4A-GE.
Feb 27, 2007 at 2:54 AM
Suggested Repair
On a similar early-1990s Corolla, the fuel filter is on the driver's side directly below the master cylinder, with a banjo bolt on top and a double inverted flare fitting below. Relieve fuel pressure by running the engine and removing the fuel pump fuse or relay until it stalls. Access is improved by removing the air cleaner and throttle-body hose, the driver's-side splash cover, and the left front tire. Use a flare wrench, retain both copper washers, and install the lower fitting first without cross-threading.
Conversation Summary
The owner asked where the fuel filter is on a 1992 Toyota Corolla 16-valve four-cylinder and how difficult it is to replace. One reply guessed it was at the back of the engine and suggested relieving pressure and raising the car. An expert said it is under the intake manifold on the driver's side and accessed from underneath, after stalling the engine by removing the fuel pump fuse or relay. Another expert said that on a similar 1991 model it sits below the master cylinder and described the banjo and flare fittings, access points, copper washers, and careful installation. The likely engine was identified as a 4A-FE or 4A-GE.
