1990 Toyota Corolla Water Pump Location
FRANSO
Hello, where is the water pump on a toyota corolla dx 1990? How can I know if it has been removed?
Apr 29, 2006 at 3:42 PM
LOSONE
  • 1,616 POSTS
Look at you fan and it bolted to the water pump. It comes in two pieces with or without a housing. Easy replacement.
May 1, 2006 at 4:17 AM
Suggested Repair
Locate the water pump by inspecting the cooling fan, which is bolted to the pump. The pump may come in two pieces, with or without a housing, and is described as an easy replacement.
Conversation Summary
The owner asked where the water pump is on a 1990 Toyota Corolla DX and how to tell if it has been removed. The expert said to look at the fan, which is bolted to the water pump, noted that the pump comes in two pieces with or without a housing, and said replacement is easy.
