1990 Toyota Camry Grinding No Start
TOYOTA
DSPATH25
Occasionally, when I turn the key, my car won't make any sound, but all the lights will come on. Othertimes, my car will make a grinding sound, but the engine won't start. The rest of the time it will start just fine. My oil light always stays on for ten seconds or so after starting.
Dec 18, 2006 at 6:22 AM
BACKYARDMECHANIC
  • 337 POSTS
I don't think it's the alternator or battery that is your problem. If it was the alternator or battery it would probably happen all the time. Try and check the connections at the battery. Make sure they are tight and clean. Hope this helps :D Backyardmechanic
Dec 18, 2006 at 6:55 AM
DSPATH25
btw, sorry i didnt give the info earlier.
toyota camry 90 deluxe 4 dr, 4 cyl, 1500000 miles, auto trans.
a little more detail to the question: when I start my car and it makes the grinding sound, it sounds as though the starters is stripping the flywheel, or just slipping, but it makes a whirring/grinding sound and my engine does not turn over?
plz help
Dec 18, 2006 at 12:44 PM
BACKYARDMECHANIC
  • 337 POSTS
Does the noise happen all the time or only when it won't start If the noise only happens when the car won't star then you are back to the cable connections. If it happens every time you start the car then there is a problem with the starter or the flywheel is missing teeth.
Dec 18, 2006 at 11:08 PM
CAPTAIN HANK
  • 32 POSTS
With the amount of miles on your car I agree with the last answer. Check your starter and flywheel first. Either one/or both of these could be the culprit.
Dec 23, 2006 at 4:27 PM
Suggested Repair
Check that the battery cable connections are clean and tight. If the grinding occurs only when the car will not start, focus on those connections; if it happens on every start attempt, inspect the starter and flywheel for missing teeth.
Conversation Summary
The owner of a 1990 Toyota Camry reports intermittent no-crank conditions with the lights on, occasional grinding without the engine turning over, and normal starts at other times. The oil light also stays on briefly after starting. Experts say the intermittent symptoms make the alternator or battery less likely and recommend checking the battery connections, starter, and flywheel.
