95 Carina with no electrics
MRROB
  • 1995 TOYOTA
I hve had a flat battery for a few months, I know it needs replacing but these things cost quite a lot. I have been charging it up every now and then or using jumps leads when the battery went completely flat. The car has already started immediately when I use jump leads so there is no other mechanical problem.
However, the other day when I was in a bit of a hurry, I put the jump leads on the wrong way on my Toyota, now it won't even start using jump leads and all the electrics no longer work. What have I done?
Monday, April 24th, 2006 AT 2:34 AM
LOSONE
  • 1,616 POSTS
First a car needs a battery PERIOD. Without a good one it overworks the charging system.
Check all of your fuses. I think you might have blown the main 60 or 100 amp fuse.
Let me know
Monday, April 24th, 2006 AT 7:42 PM
