Alternator got wet/won't charge
TOYOTA
CAFEWHAT
1986, toyota pick-up, 4 cylinder 22R engine with 286000 miles. I think it's a 2.8 litre engine. My power steering pump had been leaking and some of the fluid sprayed onto my alternator so I used an engine degreaser to clean the alternator and then hosed the debris that fell off. Not harshly, just a splash of water. Immediately my dash Charge Light came on and Dash Brake Light andI did this to locate the power steering leak-hose,or pump.The alternator has since tested as bad. Will this dry out? I now have used brake parts cleaner to cleanse and evaporate the area of the alternator. Still, 3 days later, my Charge light is on and alternator is not working. Any advice is helpful.
I placed a previous question but thought I should do so again with the title depicting wet alternator.
Sincere Thanks,
Cafewhat
May 21, 2007 at 6:38 AM
ZONER CHICK
  • 19 POSTS
I'm pretty sure you fried it. Water and electrical components don't mix. Or a hot engine for that matter.
May 21, 2007 at 4:02 PM
SHANEGUN
It is possible that youmay have shorted out the regulator. Depending on if the regulator is external or internal youcan either replace the regulator or you may have to replace the alternator.
A little water shouldnt hurt the alternator/regulator , it may be the combination of brake cleaner and water that damaged the seal or laminate on the circuits and caused the circuit to short.
May 22, 2007 at 12:16 AM
