1981 Other Toyota Models alternator overcharging frying volt
1981 TOYOTA
130,000 MILES • 4 CYL • FWD • MANUAL
WILLGIRRES
I have a 1981 toyota starlet and the voltage regulator is burning up i replaced the alternator and regulator. checked the wiring and cannot find a short.
Sep 24, 2008 at 4:33 AM
  • 75,988 POSTS
Check all connections on the battery and alternator-makes sure its wired correctly in accordance with the electrical wiring diagram.
Start the car -put a voltmeter on the battery what is the reading? Get back
Sep 24, 2008 at 7:05 AM
WILLGIRRES
the alternator is wired correctlty and the voltage reads 14.5 volts while running. but the voltage regulator is smoking
Sep 24, 2008 at 7:20 AM
  • 75,988 POSTS
It could be the alternator field windings is shorted out-
Sep 24, 2008 at 8:15 AM
WILLGIRRES
If the field windings are inside the alternator that couldn't be it i replaced the alternator
Sep 25, 2008 at 12:23 PM
  • 75,988 POSTS
There such thing as manufacture's defects-check your wiring and report back-regulator burning sounds like it not controlling the alternator
Sep 25, 2008 at 2:18 PM
