1995 Toyota Carina No Electrics
1995 TOYOTA
MRROB
I hve had a flat battery for a few months, I know it needs replacing but these things cost quite a lot. I have been charging it up every now and then or using jumps leads when the battery went completely flat. The car has already started immediately when I use jump leads so there is no other mechanical problem.
However, the other day when I was in a bit of a hurry, I put the jump leads on the wrong way on my Toyota, now it won't even start using jump leads and all the electrics no longer work. What have I done?
Apr 23, 2006 at 7:34 PM
LOSONE
  • 1,616 POSTS
First a car needs a battery PERIOD. Without a good one it overworks the charging system.
Check all of your fuses. I think you might have blown the main 60 or 100 amp fuse.
Let me know
Apr 24, 2006 at 12:42 PM
Suggested Repair
Replace the weak battery and check all fuses, especially a possibly blown main 60 or 100 amp fuse after the reverse-polarity jump.
Conversation Summary
The owner of a 1995 Toyota Carina had a weak battery and jump-started it with the leads connected backward. The car then would not start and all electrics failed. The expert said a good battery is required and advised checking the fuses, suspecting a blown main 60 or 100 amp fuse.
