Ignition Collapsed
TOYOTA LANDCRUISER
DICK2006
I have a 93 Landcruiser wagon. I cannot get the key passed the on position to start engine.
It is very difficult to put key in and turn past acc position.
Is it possible to get these ignition barrels repaired by a locksmith. Do I have to get a new ignition barrel fitted?
What is the cheapest option available to me if I have a choice?
thanks 4 your time
Dec 19, 2006 at 8:55 PM
CAPTAIN HANK
  • 32 POSTS
The cheapest option is to remove your old cylinder lock and have it repaired at a locksmith. Make sure he gives you a new set of key. By the way, did you try a different key. Usually the key is worn and doesn't have the ability to push the pins in the lock allowing you to start the car.
Dec 23, 2006 at 5:42 PM
[quote:ab25d392e2="Dick2006"]I have a 93 Landcruiser wagon. I cannot get the key passed the on position to start engine.
thanks 4 your time[/quote:ab25d392e2]
Get an ignition switch with a key to go with it or cut-repairing it might not do you any good in the long run
Dec 23, 2006 at 9:44 PM
