1999 Toyota Land Cruiser Clutch Slip
GIBBONS_MICK
Hi
I have a 99 Land Cruiser Colorado, 4x4, 3ltr turbo, and 180000 miles.
When driving in 4th and 5th and if I give some acceleration, the engine revs high and and gives no power to the drive.
Is the clutch on the way out? or will a full oil change solve it?
Thanks
Jun 19, 2007 at 11:37 AM
  • 31,937 POSTS
Hi there,
Yes i would say that the clutch is just about stuffed.
Aquick test is to start the engine hand brake on, select st gear and with a little throttle try and drive off, the engine should stall , if it lugs on a bit the clutch is slipping.
Mark (mhpautos)
Jul 20, 2007 at 7:26 PM
Suggested Repair
The clutch is likely worn and slipping. Confirm by applying the handbrake, selecting first gear, and trying to drive off with light throttle; the engine should stall. If it continues to pull or lug, the clutch is slipping and should be replaced. An oil change will not fix this.
Conversation Summary
The owner of a 1999 Toyota Land Cruiser reports that in 4th and 5th gears the engine revs high under acceleration without delivering power, and asks whether the clutch is failing or an oil change would help. The expert says the clutch is worn and slipping, and recommends a first-gear stall test with the handbrake applied to confirm.
