Gear Problem
GIBBONS_MICK
Hi
I have a 99 Land Cruiser Colorado, 4x4, 3ltr turbo, and 180000 miles.
When driving in 4th and 5th and if I give some acceleration, the engine revs high and and gives no power to the drive.
Is the clutch on the way out? or will a full oil change solve it?
Thanks
Jun 19, 2007 at 11:37 AM
  • 31,937 POSTS
Hi there,
Yes i would say that the clutch is just about stuffed.
Aquick test is to start the engine hand brake on, select st gear and with a little throttle try and drive off, the engine should stall , if it lugs on a bit the clutch is slipping.
Mark (mhpautos)
Jul 20, 2007 at 7:26 PM
