Toyota Land Cruiser Weak Brakes
ROCKYARUN
we have a Toyota land cruiser 6 cylinder petrol engine vehicle. The vehicle is armoured and used for security purpose. The problem is in the brake is not effective. Pedal seems to be good but vehicle will take long distance to stop. in other way brake is not effective.
We replaced brake servo master cylinder, wheel cylinder, front brake pads and rear brake shoes. brake disc and rear brake drums. Still the vehicle is taking long distance to stop.
This vehicle don't have ABS. Iam tired replacing all the parts even the mechanic is also confused.
If you any idea please advice. your idea is really helpfull for us.
May 4, 2006 at 1:25 AM
LOSONE
  • 1,616 POSTS
For every 500 pounds you increase the vehicle weight you decrease the brake effectiveness by 15%. You do the math.
INSURE you use toyota brake pads or a heavy duty pads.
Has the mechanic checked brake pressure? While bleeding the fluid should really squirt. You could have a low flow proportioning valve or a brake line that is either smashed or stopped up.
Tell your mechanic that anything made by man can be fixed by man. TTFN
May 4, 2006 at 9:42 AM
Suggested Repair
Check brake hydraulic pressure and flow while bleeding; fluid should squirt strongly. Inspect for a restricted proportioning valve or a crushed or blocked brake line. Use OEM Toyota or heavy-duty pads. Note that armor weight reduces stopping ability.
Conversation Summary
The owner of an armored Toyota Land Cruiser reports long stopping distances despite a firm pedal. The servo, master cylinder, wheel cylinders, pads, shoes, discs, and drums were already replaced. The expert notes that added weight reduces brake effectiveness and advises OEM or heavy-duty pads, a pressure and flow check, and inspection of the proportioning valve and brake lines for restriction.
